Help me find these rims
Does anyone know what type of rims these are and what size tire and rim combo I would use for this. It looks like the metal GM rims but they look deeper.Any help would be much appreciated.
Keep in mind that that HHR had WIDE fendors added. Those would never fit on an HHR that had stock fender wells. To my knowledge Teazer never sold any and have long ago stopped offering them.
Check with Diamond Wheels
http://www.diamondracingwheels.com/
They make all sorts of steel wheels and you can get them to make up almost anything you want.
Keep in mind that HHR is a total makeover from the ground up. Tube frame rear wheel drive and all. Someone here had posted a video of the build. It was built on NASCAR platform I believe. Being RWD those wheels will fit all day long and never would fit on FWD with that offset and backspace.
Thanks for your help everyone just one more question, if I find a wheel I like , as long as its 5x110 bolt pattern will it fit or what other factors do I have to look for,does the offset have to stay under a certain number and for the 17 or 18 inch rims what are the widths I have to be concerned about?
