Moons on Steelies
Old 10-29-2008 | 11:32 AM
andoll83's Avatar
Moons on Steelies
Will these fit on my 15" winter steelies?
http://www.hubcapmike.com/bhc01-15.html
They would look great (how are they removed?)
Old 10-29-2008 | 11:59 AM
Ratracer's Avatar
Should work
They are just a push on pressure fit. The tabs(which run the whole circumference of the back) at the bottom of the photo grip the inner offset rim edge. You just pry off with a flat screw driver.
Old 10-29-2008 | 12:32 PM
spotty's Avatar
Cool No!!!
Hello:
Do not buy----they are cheap, look great and go on and off easy----BUT----they travel and can cut off your stems if yoyu are not careful--and--there is no fix!!
beware--I bought and had to send back.
Old 10-29-2008 | 01:17 PM
andoll83's Avatar
Hmm.... anyone out there found a way to stop the travel?
Old 10-29-2008 | 01:24 PM
oneton's Avatar
You have 15" wheels on your HHR? do they clear the brakes in the front
Old 10-29-2008 | 01:27 PM
andoll83's Avatar
They're coming from TireRack today.... not sure when i'll have them put on, but I've been told that they will fit, according to people in this forum (i don't have an SS).... about 12" of snow fell here in northern New York last night, so they can't go on my HHR son enough! (I'm a teacher, so that = a snow day!)
Old 10-29-2008 | 02:10 PM
andoll83's Avatar
Anyone had any better luck with Hubcap Mike's moon covers? I'd love to get them for the winter, but I don't want to cut the valve stems
Old 10-29-2008 | 03:05 PM
badboy69's Avatar
yep they actualy due. I also have 15'' for winter on mine
Old 10-29-2008 | 05:51 PM
kwboydston's Avatar
I have a set and only one creeped, if you look closely you will see that the teeth band may not be seated all the way causing it to loosen just enough to let it creep. since I reseated mine I have had no trouble.
Old 10-29-2008 | 07:29 PM
andoll83's Avatar
They look good, I'm thinkin' about it
