Saturn Sky/Pontiac Solstic rims?
#32
the bracket I ground is wleded to the strut housing, I only actually groung off about a 1/16 of an inch, by no means will this hurt or affect anything. I am a welder/fabricator for my profession, and if I thought it would be a problem by removing material I wouldnt have done it. I have done custom suspension on other vehicles includeing a custom 4 link suspension with air ride on a ford ranger, and have done suspension work on dirt track race cars. All I am trying to tell you is that if you dont use spacers with solstice/sky wheels, they will rub the sidewall of the tire on that edge of the bracket.
#35
I am not trying to sound rude or be an ass, but I am just telling you what I had to do, and also I have talked to other members with the same wheels as me and they said the same thing about having to shim the wheel out and that a 245/45R18 will not fit up front without rubbing the strut where the bottom of the coil spring sits.
#36
I didnt take it as such. 8-D Infact I have taken to quit the contrary. I am keeping in mind that I will probably have to do that anyways. I really do appreciate all your help, and hope I didnt come off wrong.
#37
Here is a good site for matching up the HHR's 110 bolt pattern with other stock rims.http://www.roadkillcustoms.com/hot-r...udSpreadMM=110
#38
Does anyone know if 245/40 18" fit. I was reading some people putting them on their SS rims. I'm assuming they had more clearance because of the 1/2 inch difference between the stock SS rims and the wider Solstice rims. Any thoughts or suggestions? Because I'm going to be buying some tires next week for my solstice wheels.
#39
ive got 08 hhr lt that i just put 5 spoke chrome wheels off a pontiac solstic with no mods n no problems with 225 45 18s no rubn nothen no grindn maybe i got special ones lol.. i was thinking of running 20s in the front n 22s in the back make it more hoty rodish wonder if 22s will fit in the back.
#40
Infinitys & Nassans that use different sizes are calibrated for that.
