Tire Reccomendations!
Old 10-14-2009 | 09:10 AM
FXM's Avatar
FXM
I have a 2007 HHR Premier Edition. I have just noticed a bubble on one of my tires. I plan on getting the tire replaced this weekend. The question I have is, should I get all 4 tires replaced at the same time. The HHR has 28, 000 miles on it at the moment. Any suggestions would be appreicated.
Thanks!
F.X.
Old 10-14-2009 | 09:24 AM
Doc brown's Avatar
How's the tread? If you think you'd be replacing them in another 10k, you might want to just get it done. What ever you do, don't replace just one. Do either 2 or 4 at the same time.
Old 10-16-2009 | 10:27 AM
HeavenlyHellRaiser's Avatar
Yeh if your gonna change one might as well get all 4 while your there, might save you a little cash to do them all at once. If you have the money to spend on a good tire I would spend it.
Old 10-16-2009 | 03:04 PM
Comfortably Numb's Avatar
Definitely do at least 2 tires. They have 28,000 miles on them, new tires will have zero. Think about it.
Old 10-16-2009 | 03:08 PM
ChevyMgr's Avatar
Thanks!
F.X.
If it's not damaged due to impact it's covered by the 3/36 warranty.
Old 10-16-2009 | 03:30 PM
gcsd3742's Avatar
run these:
http://www.performanceplustire.com/p...310#prodAnchor
Old 10-16-2009 | 10:34 PM
Rainman's Avatar
Nice!
Old 10-16-2009 | 10:42 PM
harleysshhr's Avatar
for the best handling and ride change all four. The DOT also recommends doing just that. Ask yourself if there are any benefits other than financial to changing just two and you have the correct answer. Easier yet, if someone were to replace the tires for you at no charge, would you want to leave two old half worn out tires on the car along with two brand new tires.
PWRWGN
10-28-2013 08:50 AM
postalboy
Tires & Wheels
11
05-25-2013 02:00 PM
dumpratray
Tires & Wheels
03-28-2013 08:41 AM
bthomas515
Tires & Wheels
13
06-11-2011 09:03 PM
