tire size
Old 07-02-2012, 11:22 AM
mmont50's Avatar
tire size
I have a 2008 LT2 Panel which has 215/50R-17....I have found a good deal on 4 Eagle GT 225/50R-17. At this dealer I can't get the 215, my concern is will the 225 rub...?
thanks Mike M
Longmont, CO
mmont50 is offline
Old 07-02-2012, 11:32 AM
mount one up and try all four corners, how much wider can 10 MM be?
Oldblue is offline
Old 07-02-2012, 11:40 AM
prod's Avatar
Im running 225/55/16 which are about the same diameter, lots of room still. You can try one of the online tire size calculators, I think the max is 26.2"?
prod is offline
Old 07-02-2012, 02:11 PM
solman98's Avatar
Pretty sure Sleeper is running 225/50 17's and no issues. They run just under the strut plate.
solman98 is offline
Old 07-03-2012, 12:29 AM
Solman- Yes I am running 225/50/17's.. Best move I made..
Plus I know Greybeard is running 225/50/17's Eagle GT on his '07, & no issues either..
sleeper is offline
Old 07-03-2012, 12:31 AM
the 10MM wider is measured at the section width, not tread width.
sleeper is offline
Old 07-03-2012, 01:06 AM
jeff schaffer's Avatar
I'm running 225/45/ 17 No problem
Like to do 18 in the future came with 16
factory.
jeff schaffer is offline
Old 07-03-2012, 01:12 AM
factory.
Jeff- That's a short tire.. 24.97 compared to 25.5 for a 215/50/17
When your speed-O reads 65, you are doing about 63.4 mph..
sleeper is offline
Old 07-04-2012, 09:03 AM
audioman's Avatar
I have 225/50/17 on my 07 ... no issues at all
audioman is offline
Old 08-26-2012, 08:09 PM
Silverfox's Avatar
Whats the benefits you have realized?
SF
Silverfox is offline
Quick Reply: tire size
