tire size help 225-50-17 fitment
Old 09-14-2011 | 12:30 PM
HOTRODSURFER1's Avatar
my 07 hhr has 215-50-17 firstones on it now -would like to go up to a
225-50-17 -any one run this size on ther hhr???
Old 09-14-2011 | 01:55 PM
Yup..... Not a problem.
Old 09-14-2011 | 04:18 PM
thank you sir!! want to fill my wheel wells a bit
Old 09-14-2011 | 04:23 PM
I've got 225/50ZR17 Goodyear Eagle GT's on factory wheels for my winter tires..... Highly recommend those tires. I run the same tire in the summer but in a 16" size. Check them out!
Old 09-21-2011 | 06:05 PM
Mongosride's Avatar
I run 225/50/17's on 17x7 ADR Propultions with no proplem at all. Handle way better, and tire wear is incredible. Good luck!
Old 09-21-2011 | 06:13 PM
panelmoxie's Avatar
great information.
Old 09-28-2011 | 04:33 PM
Bob Cavicchio's Avatar
do you get a better ride with the 225s? my hhr with the stock 17" firehawks rides like a hardtail Harley. Would it affect warranty?
Old 09-28-2011 | 05:08 PM
I get much better performance as the Goodyear is a much better tire than the Firecr@p it came with. A 17" tire will always feel a little "stiff" as there's not a ton of sidewall there, say as there is on a 16" with the same diameter. The 225 measurement mostly gives you a wider tire.... not a taller one, and you won't be able to go much taller than this 225/50R17.
Should not effect warranty.... if somebody says it does, I'd try another dealer. Beware, some of these dealers try void your warranty for anything..... like, you know, air-fresheners and such.....
Old 09-28-2011 | 06:18 PM
5speed4's Avatar
You guys that are running the 225/50R17, can you check to see how much room you have between the top of the front tire and the lower spring perch? I'm wondering if I can fit a set of 215/55R17's on there (26.3" diam). They'd need about 0.225" more clearance than the 225/50R17's. So do you have about a quarter inch clearance there?
Based on my current 215/50R17 tires, it looks like they would fit, but my tires are old
and worn down, so that may be fooling me.
Old 09-28-2011 | 07:12 PM
That's going to be brand specific as each brand will have a slightly different actual diameter. Also the shape of the shoulder will have some bearing on fitment as well. If you find a brand that does fit I wouldn't drive down to many gravel roads...... a little bit of clearance is a good thing.
I never took a ruler to it but my finger tips won't even begin to go in that gap and I have skinny fingers.
