Tire Size/Wheel Clearance Question
Old 03-22-2009 | 03:45 AM
PrimerFender's Avatar
Lightbulb Tire Size/Wheel Clearance Question
Hey hows it going?
I'm up for new tires on my HHR and wanted to go with something slightly larger to fill out some of the fender well without investing in bigger wheels, lowering, body chops etc.......
I have the 215/50R17 stock shiny aluminum wheels on right now. I like the wheels so I'm keeping them. I was thinking a 235/50R17 would be slightly wider, slightly taller (slightly off on the speedo) but I don't know if it will clear without rubbing on anything like the strut, the fender wells, either under compression or on turn in.
Has anyone run this size on the standard 17" wheel? Does anyone know if this will rub. I guess I could always have them installed and try it but would prefer to know ahead of time.
Thanks!
Old 03-22-2009 | 08:20 AM
tireman1554's Avatar
Your best bet would be a 245/45R-17.
Old 03-22-2009 | 11:56 AM
jeffs396's Avatar
to the site! A 225/50/17 on stock wheels fits nicely...a bit closer to everything, but no rubbing. Here they are on mine with Eibach pro lowering springs...BTW, I thought about the 235/50/17, but tire choices are limited & I think they may rub.
Old 03-23-2009 | 05:13 AM
Thanks for the response!
jeffs369, I like how your tires bow out a little instead of looking flat...maybe it's just me but I think tires should be round ;-). Are those stock width wheels?
tireman, do your tires rub under full lock? It seems they would do that with the extra width room?
Old 03-23-2009 | 07:24 AM
Nope. I haul three teenagers and all their luggage every weekend and have never rubbed.
Old 03-23-2009 | 08:40 AM
mistermike's Avatar
The clearance pinchpoint is the strut flange, not the fender well.
Old 03-23-2009 | 10:50 AM
jeffs396's Avatar
My wheels are 17" x 7" G6/Aura steelies...a bit wider than stock.
True in the front, but in the rear, these taller tires come fairly close to the plastic inner wheelwell liner also.
Old 03-23-2009 | 07:23 PM
cool, thanks all!
SwaintaN
Tires & Wheels
38
06-24-2020 09:33 PM
awqueen1986
Tires & Wheels
03-02-2012 10:21 PM
PAT HHR08
Tires & Wheels
02-06-2012 10:20 PM
1_FAST_SS
11-04-2010 01:31 AM
giant96
Tires & Wheels
09-03-2006 09:30 PM
