Tires..will these fit?
Old 09-10-2013, 04:41 AM
retrolled's Avatar
I have the opportunity to buy these wheels and tires but they are 225/50/18 will they fit ok, their off a G6 and should have the same back spacing and all. I'm more worried about tire size. Thanks
retrolled is offline
Old 09-10-2013, 06:16 AM
Assuming you're talking about the factory G-6 18x7" rims fitted with that tire size, you're probably going to have an issue with them rubbing.
That tire/rim combo will have an O.D. of approximately 26.9", anything over 26.1" in O.D. will rub the inner sidewalls on the lower front spring perches.
Spacers may alleviate the sidewall rub, but they bring their own set of headaches.
843de is offline
Old 09-10-2013, 03:59 PM
retrolled's Avatar
Their after market wheels but assuming they prolly still have the same back spacing as stock, not sure! Their einki wheels.
Old 09-10-2013, 05:04 PM
But as Mike said above, the tires are too tall and probably won't clear the lower strut perch.
firemangeorge is offline
Old 09-10-2013, 05:11 PM
retrolled's Avatar
Anyone running 225/50/18s
Just wanting to see if its possible to get the wheels I'm looking at to fit with minimal to no modifications. If anyone does have them I would appreciate pics if you could load some. Thanks
Old 09-10-2013, 05:14 PM
Uh. Don't you already have 1 other thread about this??
Old 09-10-2013, 06:11 PM
retrolled's Avatar
Uh kinda... But this one is asking if anyone is running this size.
Old 09-11-2013, 10:02 PM
Merged the threads to avoid confusion, duplicate answers, and just plain getting lost on the forum.
843de is offline
Old 09-12-2013, 05:28 AM
retrolled's Avatar
Thank you 843, I thought about it after I posted but I'm not sure how to delete or move post on here.. Kinda olskool I guess!
Old 09-12-2013, 06:47 AM
Give this thread a read, check out post #2, SS fan is our unofficial 18" tire size expert here. He swaps tires out like a NASCAR pit crew at a short track, I've kinda lost track of how many brands and size variations that Sam has tinkered with.
https://www.chevyhhr.net/forums/hhr-ss-45/what-tires-will-fit-ss-44189/
843de is offline
Quick Reply: Tires..will these fit?
