Tires..will these fit?
I have the opportunity to buy these wheels and tires but they are 225/50/18 will they fit ok, their off a G6 and should have the same back spacing and all. I'm more worried about tire size. Thanks
Assuming you're talking about the factory G-6 18x7" rims fitted with that tire size, you're probably going to have an issue with them rubbing.
That tire/rim combo will have an O.D. of approximately 26.9", anything over 26.1" in O.D. will rub the inner sidewalls on the lower front spring perches.
Spacers may alleviate the sidewall rub, but they bring their own set of headaches.
Anyone running 225/50/18s
Just wanting to see if its possible to get the wheels I'm looking at to fit with minimal to no modifications. If anyone does have them I would appreciate pics if you could load some. Thanks
Give this thread a read, check out post #2, SS fan is our unofficial 18" tire size expert here. He swaps tires out like a NASCAR pit crew at a short track, I've kinda lost track of how many brands and size variations that Sam has tinkered with.
https://www.chevyhhr.net/forums/hhr-ss-45/what-tires-will-fit-ss-44189/
