TPMS question
Old 01-15-2013 | 07:35 PM
OregonHHR's Avatar
TPMS question
I have figured out that chains will not work on our HHR's so now it's on to studded tires. I have found a set but they do not have the TPM's in them how much of a PITA is this going to be?
Old 01-15-2013 | 07:39 PM
skyline26's Avatar
just use them without the sensors..u will just have the "!" on your dash on but who cares..sensors are too expensive
Old 01-15-2013 | 07:47 PM
OregonHHR's Avatar
I am going to the guy quoted me $350.00....wow...no thanks
Old 01-15-2013 | 07:48 PM
skyline26's Avatar
thats cheaper for sensors then here in canada lol
Old 01-15-2013 | 08:51 PM
Sno White's Avatar
In 2010 Tire Rack sold me the sensors for $34 each, installed in a tire/wheel snow package.
Old 01-15-2013 | 08:56 PM
skyline26's Avatar
i was quoted ~$110 per sensor and $12 for each screw to attach to rim
Old 01-15-2013 | 08:59 PM
badassbowtie's Avatar
I'm not sure how different studded tires are, but if the are the same thing as a normal tire with studs in them, then you keep your TPMS sensors and it should be fine. the sensor is attached to the valve stem and is pretty small.
I installed new tires in july and you can do the tires with out touching the sensor
UNLESS, you are using different rims, in which case ignore my post
Old 01-15-2013 | 09:36 PM
OregonHHR's Avatar
Yep different rims so I can change out the studded tire easily.
Chevyhhrfan
02-25-2015 08:26 AM
gerrbear
Tires & Wheels
09-26-2012 05:53 PM
stanvalp
03-16-2012 03:06 PM
BlackknighT
08-19-2011 08:15 PM
Lil Cheney
02-19-2009 09:04 AM
