What about these 20"s
Old 11-23-2009 | 07:06 PM
Gmando's Avatar
I found this package on ebay and I kind of like it with the exception that I wish the wheels were black, but I may have them painted.
Let me know what you guys think of the look for this car, I like the deep dish look.
What issues (if any) could I expect to encounter if I put these larger wheels on my SS????
Also, I'm sure this topic has been touched in the past, but I don't know who to search this site. How do you search?
here is the wheel package: http://cgi.ebay.com/ebaymotors/NEW-H...Q5fAccessories
or item number on ebay: 270481023245
Old 11-23-2009 | 08:23 PM
gcsd3742's Avatar
look up close to the sign out, then go over 2 and SEARCH button is right there.....
Old 11-23-2009 | 09:03 PM
Father Azmodius's Avatar
Larger wheels generally mean more rotational mass. That additional mass will lengthen braking distances. The ABS, and TCS will be affected if the overall diameter is significantly different as well. A shorter sidewall could translate to a rougher ride. I my opinion, when going with big wheels, the brakes need to be bigger for aesthetics, big wheel/little rotor just looks stupid to me. Feel free to ignore my opinion though, because I know I'm biased.
Old 11-23-2009 | 09:22 PM
KinseySS's Avatar
This might be a stupid question but what kind of alloy are those wheels?
Old 11-23-2009 | 10:57 PM
moonsign's Avatar
The ecu is geared up for 18" wheels with a 45 series tire.
If you don't mind your speedo and other stuff being off, then jump on it.
Bear in mind that your SS will look sort of like a covered wagon, being jacked up in the air with 20'S. You'll have plenty of ground clearance.
Old 11-24-2009 | 08:04 AM
jerSSey HHR's Avatar
I'll stick with the 18s.
Old 11-24-2009 | 10:36 AM
garagebuilt's Avatar
if you dont care about the ride being a little rougher and the wheel sticking out go for it.
your speedo wont be off if i looked up the right size to compare
Old 11-24-2009 | 10:39 AM
Gmando's Avatar
I plan to install Pedder spings so it will look just like the images some of the guys have on here at the botton of their post. Hope it doesn't rub, but I'll find out.
Old 11-24-2009 | 10:41 AM
you need to find out the offset to know if they will rub
Old 11-24-2009 | 12:06 PM
RoadDawg831's Avatar
Ditto here. GM spent big bucks in engineering to make the SS handle like a performance vehicle and I personally can't see spending good money to negate those attributes.
Quick Reply: What about these 20"s
