Wheel hub bore?
When you buy the wheels for the dealer, ask if they are hub-centric which means that the bore of the wheel will match up to the hozzel on the brakes. If they are not ask about the hub centic rings. They are small plastic or metal rings that make the wheels hub centric. You don't have to have them. I hated themm because they would break, crack, and melt. Most wheels that are 5-110 bolt pattern seem to be lug centic trough.
jbiesent
44
05-09-2016 01:11 PM
dudley
04-15-2012 12:06 AM
