Wheel/Rim Width
Old 04-28-2010 | 09:43 PM
andoll83's Avatar
Wheel/Rim Width
I'm in the market for new rims (pothole damage / shaking).... I currently have the stock 17x6.5, 42mm offset, 5x110mm bolt pattern. I want to use my same tires (215/50R17).... my question is: would 17x7 work? or 17x7.5 with those tires? Does the offset have to be exactly 42mm?
Thanks very much,
Andy
Old 04-28-2010 | 09:55 PM
harleysshhr's Avatar
Answers- Yes...Yes...& No. Hope that helps
Old 04-28-2010 | 10:12 PM
andoll83's Avatar
is exactly 65.1mm for the center bore important?
Old 04-28-2010 | 10:19 PM
You cannot install a wheel on your car that has a smaller center bore than that of the center bore of your car. If the wheel has a larger center bore that's okay. But if it is larger it is always recommended to use hub centric rings that fit both the wheel and your car.
Old 05-11-2010 | 09:59 PM
andoll83's Avatar
I like these... how would they look on a black hhr? Is it ok that they're 17x7.5? (My tires are 215/50R17)
http://www.sears.com/shc/s/p_10153_1...Wheels&prdNo=5
Old 05-12-2010 | 12:22 AM
That is a good choice. That rim size will fit good.
Old 05-12-2010 | 07:03 PM
andoll83's Avatar
is a 35mm offset too small?
Old 05-12-2010 | 07:22 PM
No, it's not too little offset for the HHR with the rim width that you are referencing to.
Old 05-12-2010 | 07:35 PM
ZTony8's Avatar
The special edition from 2008(the granite metallic one) had 17X7 rims that look just like the factory 5 spokers, if you're interested in keeping that style wheel.
Old 05-12-2010 | 08:05 PM
andoll83's Avatar
stock rims go for around $250 each, though.... trying to avoid that
SMH2010SSHHR
05-21-2015 09:16 AM
pat hhr
Tires & Wheels
03-01-2011 09:35 PM
moonsign
Tires & Wheels
05-23-2010 12:39 PM
ballplr
05-12-2008 08:13 PM
stick
7
01-28-2008 08:12 PM
